Report
bgaudreau
Forum User
I was wondering if there is any report in 3CX where you can see the amount of call receive during a specific period of time during a month.
Example : Every call between 5PM and 11PM during the month of June 2019.
I already checked and the only way I see would be to pull out all the calls for the month of June in a CSV file and manually filter the data after but it's a lot of work for what I need, so I just want to make sure that it's the only option before doing it.
Thank you.
3CX Version : 15.5.6354
Thank you.
If you have a Pro or Enterprise license, you can use the integrated reporting feature.
I have the Pro licence and I looked at the report already but when I look at every report I can specify a month but not the time for each day of that month like in my example.
Thanks for your help
Have you tried using the CDR service and maybe a small custom app to grab the CDR and generate the report? I think VoIPTools already does something similar to this.
I do agree that custom timerange is needed for those reports!
If, by any chance, you have CDR's available for this period in the correct format then this would be easy with CallSequitur... You can enter advanced search terms to directly view & report on calls meeting your time window criteria.
Hi @bgaudreau
You can download a report in CSV format, and then manipulate it in Excel to show the very specific things you want by filtering out other results
CDR wasn't enabled on that server so I will have to go with the excel solution.
Thank you for your help.
bosdorf
