Solved Reporting with Specific Extensions
Bhav Panesar
Forum User
Hi all,
I wanted to know if there is a way to specify extensions in the weekly reports we have. We have extensions in the 30 range and in the 80 range, but I'm not able to specify these. Does anyone know a workaround for this? E.G. need Ext 34 & 83, 84 and 85 - Doing 83 - 85 works but then I can't add Ext 34.
Thanks in advance, everyone!
You should be able to enter 83-85,34 on the extension field.
You can combined multiple entries i.e. 10-19. 50-50 , 34 , 36 into this one field
Reactions: Bhav Panesar
Without spaces, hah, now that makes sense. Big thanks @Saqqara ! Looks like it's accepted it fine.
Reactions: YiannisH_3CX
jlucero
