Reports like CDR
Simone Rota
Forum User
I activated the CDR in June but I would like to attach the data with the previous months
Is it possible to create Reports with the same fields as the CDR?
Simo
Hi Simo,
You will have to generate a manual report in CSV and manipulate it in Excel the way you want.
Try a generating a few different report types to see which one contains the data you prefer.
Manual Report? How?
Just look in your management console here, but note that this is a Pro/Enterprise license feature
12199
I tried but there are no fields as historyid e callid
Yes its not the same as CDR, you will have to check different report types and see if there is something similar to your specific needs.
It won't give you the same as CDR of course, these are just reports so it might not give you exactly what you are looking for.
bosdorf
