Reset license
it-basixs
Hello.
I would like to install the telephone system on a new server without using the BackUp because I want to change the FQDN, which is only possible with a new installation. Unfortunately the license can no longer be activated. How can you "reset" these?
Thx
Andreas
If you want to start fresh, you can release your FQDN from your 3CX Customer portal, and then proceed with a new installation using your key. You just click on the license, and there should be a release button on the next screen:
Since there is no FQDN assigned to the key now, you will be asked to select one during setup.
Probably this is not the email address you used to register that key ?
Hello. Do I have to log in with my customer's email address to change this. I am the main account / reseller.
If you are the reseller, then the customer will need to log in and release.
They must log in with the email account which received the initial activation email.
ok, thx, i try it...
[email protected].
