Solved Restore backup from v14 to v16
Blyzr0
I'm trying to restore a backup from version 3cx v14 to version 16, but this seems problematic. I have a license for version 16 and I can only restore the backup from version 15.5. I know that version 15.5 has the option of restoring a backup from version 14, but I can't even install it because I don't have the license key for version 15.5. What am I suppose to do with it? Is there any way to get a trial key for version 15.5?
Regards
Hi @Blyzr0
Your v14 key should work for v15 (It will upgrade the key)
Regards
Do you have an already running V14 system, or do you just have the backup file?
I have a key for v11 which i currently use. I managed to convert my v11 backup to v14. I used key from v11 and it worked on v15.5. Now I can do backup and import it on v16. Thanks for advice
Glad to hear it was resolved :)
intoxtech
