Restoring from backup
matjaz
I have an issue with restoring a backup. I have a backup from september 2022 and want to restore it to compare some configuration that's been done since then.
This is a Windows installation and the backup version is 18.0.3.461. I created a new test VM and installed the latest 3CX v18 Update 6 and during installation chose to restore from backup file. I used a test license and a test FQDN for this test installation. After the installation is complete I can log into the console but the restore wasn't successfull aparently, since most of the configuration is missing (no SIP Trunks, only 1 extension,...). I can see in the .xml file that there is info about two SIP Trunks and all of the extensions.
Is there another way I could restore this backed-up instance to check some of the config? The .xml has about 300k lines and it's a pain to look through it.
ARKC
