Restriction of incoming calls to a single extension.
Malyar
Hello everyone,
I have a task to set up a restriction for incoming calls to a single internal extension (for example, 3403) in 3CX.
Only a specific list of 15 extensions should be able to call this number.
If someone else tries to call, the call should be immediately dropped or redirected, for example, to an IVR or a “number unavailable” message.
As far as I can tell, there is no built-in option like “Allow calls only from these extensions” (at least not in 3CX v20.0 Update 7 Build 1060).
I’d like to know if this can be implemented in any way — through the Call Flow Designer (CFD), a custom routing rule, or perhaps using some hidden PBX parameters.
I’d really appreciate if anyone could share their experience or an example of a similar setup.
Thanks in advance for your help!
Exceptions in call forwarding. They're there for this.
Reactions: Malyar
Hello @Malyar ,
As mentioned by @ConceptsWeb you can navigate to Admin > Users > edit a user > Call Forwarding > Exceptions. There you can configure the exception rules for the specific extension. For example 100-110 extensions will not be able to call the specific extension.
Hello Malyar,
The guy's before me already have explained that it is possible.
Here as extra, just an example, that I use:
We use the filter in the caller-ID: 000-199,210-999
This means that all 3 digits numbers (except 200..209) can NOT dial this extention.
By using the dash - you can select a range, and with the comma add extra information.
Paulo
Thank you, all. It all worked out.
ARKC
