Ring calls
Hugzzz57
Hello, i was on a V16 debian 9 system and I upgrade to a V18 debian 10 system and all the update was good, just a thing, I don't find Ring groups and SVI.
Are they hide or disable in V18 ??
Look at the screen if u want.
Thanks for your help
Hello there.
It looks like you are not logged in to the PBX console as the admin of the PBX but with the extension.
Make sure that the extension has " Phone System Administration" rights on and then you should see the Ring groups.
Thank you, i connect with admin and it works !
AssurancePartners
