Ring Group Timout Duration
Scott EIT
Is there any way to change the ring group no answer timeout in Startup Pro? Client is suggesting it's ringing for far too long and customers are hanging up. What is the default set to?
It's set to 60sec and there's nothing you can do to change it.
StartUP doesn't allow modifying these basic options.
Okay, thanks for the reply. Again, really dissapointing something so basic can't be modified. Having serious doubts offering this to any future customers. It's unfortunate because it's the right price band to attract new clients of a certain business size but it seems to be falling short on basic features for a basic system.
A dedicated Pro is barely 50$ more and gives you all the control you need.
$50?? Don't know where you get your pricing from but it's a bit more than that for me I believe.
The client would like this function plus the ability to call back from a voicemail. Do these both work with a dedicated pro?
Call back from a voicemail is already implemented in the Webclient > Voicemails, the little phone button. I believe the audio menu when dialing 999(99999 on StartUP) also has it.
And I'm basing myself on StartUP Pro (175$) vs Dedicated Pro (210$), in CAD$. Not even 50$.
It's more expensive in the UK then!
Probably just exchange rates based on the USD prices.
I doubt there's so much of a difference.
Going back to the call back from VM. Is that available when listening to a message on a handset with Startup Pro?
Option 4 after a message is played should redial the number.
I don't believe you can enable this in Startup pro. If you can, where?
It's not to be enabled. It should be in the menu already. StartUP is just a dedicated system with group restrictions. It has the same backend engine.
It's in the menu, it doesn't work though.
I see, that sucks.
I agree. Along with a host of basic features that are missing. I also agree going forward it's probably worth paying the extra for Dedicated Pro.
It certainly is!
lonedigger
