Route personal DID's according opening hours/break hours/vacations of digital receptionist
Michael | EQUA
Hi Everyone,
I have the following situation. I hope I am describing the situation in the right way.
I have a trunk with a main trunk number and multiple DID's. This main trunk number and all not assigned DID's have the default route to a digital receptionist (No. 810), this digital receptionist also has the other destinations set to separate digital receptionist (when closed, when on break and when on vacation).
the digital receptionists (No. 810) does the things below:
when open it forwards to a queue.
when closed it forwards to another receptionist (No. 820) with a prompt that they are closed and ends call
when on break it forwards to another digital receptionist (No. 830) with a prompt that they are on break and ends call
when on vacation it forwards to another digital receiptionist (No. 840) with a prompt that they are closed on holidays and ends call.
When you call the main trunk number or an unassigned DID after opening hours (for example), the trunk states that the customer is closed, which is okay.
however, the DID's assigned to users are still reachable outside office hours and we would not like that. We would like that, during opening hours the DID's are directed to the users, but on closing/break/vacation, to be forwarded to the above mentioned digital receptionists.
So basically we would like them to follow the same timings and destinations as the digital receptionist, but not the same route during opening.
Is this possible to create this and if so, how can I create this? I would like it to have a solution that would not be able to be changed by a user in the webclient (due too the fact users can change the settings) , so a script or something similar would be great for that.
Thanks in advance!
Kind regards,
Michael!
"Hide call forwarding rules" in user settings should take care of not having users change themselves what happens when they are not there.
Thanks for the reply. This would set it up or the users that do not really use the webclient. but there is no other way to force this, for example with a processing scripts or something like that?
LachlanC
