Router phone connecting through itself
SteveITS
3CX MVP
I see a router phone can connect through itself. Can it be set to use 127.0.0.1, so the connection works if the phone moves to a different network and hence IP?
Thanks,
Hi Steve,
An important note: Do not attempt to manually set anything in the phone using 127.0.0.1
And yes, if you simply configure a phone as a router phone, by default it connects through its very own SBC. You don't need to make any adjustments, and you can take the phone anywhere you wish once it is configured. It can be moved across any network you wish.
... and the phone becomes kind of mobile, so to speak :)
Perfect, thank you!
Mahlon
