SAP Business One V10 Integration issue
Rynhardt81
New User
I am trying to get 3cx integration working with our SAP business one V10 ERP system but cannot seem to get the authentication right.
In postman, I have to use Oauth2.0 with variable CompanyDB,Username and Password inserted in the header and the Grant type set to Password credentials. This allows the post to go through and a SessionId is returned and all subsequent requests work.
I have tried numerous template creations and custom creations with the 3CX generator but cannot get it to authenticate.
Return header
Please advise
This is not standard OAuth2, so you will need to adjust the template after the wizard completes.
You will need to use a scenario based authentication. There you can specify those custom headers in the request element. You can check the ConnectWise template for your reference, where you will see how we specify custom headers in the request:
XML:
<Request SkipIf="[IIf([FoundRecordCount]&gt;0,True,False)]" Url="https://[Domain]/login/companyinfo/[CompanyName]" RequestEncoding="UrlEncoded" RequestType="Get" ResponseType="Json">
    <Headers>
        <Value Key="clientId">f66de42b-efaf-4ed6-a542-c1211c03d3ab</Value>
    </Headers>
</Request>
Robert Lee
