Solved SBC and 2 Phones
Chaz
SBC is up, but phones wont connect to our 3CX. I can see them in the phones, but they wont allow us to assign to a user. Fanvil phone acts like it is rebooting after a auto provision, but quickly comes back up as factory reset phone.
Same with a Yealink phone. We can see them both as new phones, but cannot assign them. We were good until we moved our windows domain controller to the other side of the VPN. Not sure if that would matter because the server wasn't playing a role with 3CX.
Thanks,
Chaz
is 5001 open on firewall SBC side ?
did you factory reset the phones and do you use latests firmware?
Reactions: Chaz
do you have access to a prosivioning file from a browser on SBC side
Paste url iun browser and see if you are able to access xml file
Reactions: Chaz
Can you try to paste manually provisioning URL in a phone from GUI and see if it provision ?
Reactions: Chaz
It says it page cant be found.
Yes, we factory reset the phones man times.
I figured it out. When we moved the server, The IT Folks thought it would be best to let the server handle all the DNS. I statically assigned the phone so that it would not use the 2008 server for DNS, and it came right up. Traditionally, we let our firewalls use google for the DNS.
Reactions: AWS2P
Yes, and pointed to the IP of the SBC.
You do no port forwarding on the firewall protecting the sbc server, remove all settings on the firewall as no firewall settings are required except allow tcp/udp port 5090 and tcp 5001 outbound
You need to have port 5001 port forwarding on the firewall protecting the 3cx server
Port 5001 is used to provision the phones
Reactions: Chaz and JohnS_3CX
Robert Lee
