SBC config reference ?
A.Takacs
I have just deployed a debian-based SBC and somehow have ended with what seems to be a generic config file
Although most of the content seems self explanatory I was wondering if there is a reference for all the fields in this file and/or an easy way to recreate it (ie to re-run the setup wizard that seems to have failed).
I think what kieferschild mentioned would be the way to go here.
If for any reason you get the same issue you may actually need to re-deploy the OS.
You mention debian-based SBC, if this is not a raspberry pi, do make sure to download and use the 3CX ISO mentioned in the guide which contains Debian 9.
If you are using a Pi 4, you might want to consider re-flashing the sd with the ISO image found in our guide before re-installing just to be safe.
zipman
