SBC Install Issue
big.LITTLE
We have 3CX Enterprise Annual 16.0.8.9 hosted on the cloud and want to add an SBC on our LAN side.
Installed using 3CX Debian 9 ISO, selected SBC on the first reboot after install, added SBC on the 3CX Management Console and got the Auth ID key, entered on the SBC installation and it says:
Unable to read the 3CX Server at https://xxx.3cx.co.uk:5001
Please double check "3CX Provisioning URL" value and confirm that the SBC Trunk is created properly from within your 3CX Management Console.
Also 3CX must have a valid secure SSL Certificate so if you have a custom certificate which has expired or not renewed, the installation will fail.
<Retry> <Abort>
I tested the SBC host can ping the 3CX server, and the certificate is obviously valid since this is a 3CX-provided FQDN.
Anyone experiencing a similar issue like us?
Bitte überprüfen Sie ob auf der Seite der 3CX Anlage das Zwischenzertifikat vorhanden ist.
-----BEGIN CERTIFICATE-----
Ihr Zertifikat
-----END CERTIFICATE-----
Ihr Zwischenzertifikat
- ----ENDE ZERTIFIKAT--- --
-----BEGINN ZERTIFIKAT-----
Ihr Stammzertifikat
-----ENDE ZERTIFIKAT-----
Ihr Zertifikat
Ihr Stammzertifikat
Das Zertifikat ist gültig.
Ich denke auch dass das Zertifikat selber natürlich gültig ist aber der SBC ist noch auf einen Zwischenzertifikat angewiesen.
Am besten via SSH sich auf die PBX Anlage verbinden und das Zertifikat analysieren, ob das Zwischenzertifikat vorhanden ist.
Does your hosted 3CX pass a firewall test? (Run a new test)
Are you using Google's DNS on your SBC? If not, can you?
@big.LITTLE
You could try first running an "nslookup FQDN" from the 3CX SBC host and if it does resolve to the correct IP try a "wget "FQDN":"PORT", if it is a certificate issue you should get an error message confirming it.
Yes, firewall test passed. No issue and all appears green.
@big.LITTLE
From the SBC host can ping (and talk with) the 3CX server FQDN.
Probably unrelated to your problem but , are SBCs install always using Debian 9 today?
Zwischenzertifikat Zwischenzertifikat Zwischenzertifikat
Yep, the ISO still based on Debian 9.
All working fine, I ran a portscan against the server and can see all the ports.
All working fine
You mean, not it's working, or that you can reach the server fine, but you are still having the problem installing the SBC?
BIT Incorporated
