SBC logrotate
Zol
Hey Community,
I have recently installed my first SBC 16.0.386 (Raspberry Pi 3B+) and I setup the Logging & Troubleshooting as follows:
12398
I would like to logrotate /var/log/3cxsbc/3cxsbc.log with compression.
Am I allowed to create a conf file under /etc/logrotate.d/ or could I ruin something?
Thanks,
Zol
Hey Community,
Thanks,
Zol
I strongly recommend you keep logging to Low on a Pi. It's IO intensive and an SDcard isn't the best IO performance.
You're right @Frederick Marcoux, thanks for the tip.
However I only connected 2 IP phones to the SBC for test purposes, so I'm not logging much (100MB per day so far).
Regardless the I/O permormance, I would like to keep at least 7 days of logs, without having to read the log from a 4GB logfile, hence my question about logrotate.
The SBC should rotate it's own log but not by days, by size. That's why we select "Log Size: 100MB".
As for IO, number of phones don't matter, just leave the log as Low unless explicitly required by 3CX Support to gather verbose logs.
Updating the thread.
I created a new conf file in /etc/logrotate.d/
$ sudo vim 3cxsbc
Code:
/var/log/3cxsbc/3cxsbc.log {
    daily
    rotate 7
    compress
    copytruncate
    create 0644 tcxsbc tcxsbc
    dateext
    maxage 10
    missingok
Then I renamed the file /etc/cron.daily/logrotate to logrotate.old and created a new logrotate file:
$ sudo mv /etc/cron.daily/logrotate /etc/cron.daily/logrotate/logrotate.old
$ sudo vim /etc/cron.daily/logrotate
Code:
#!/bin/sh
/usr/sbin/logrotate -s /var/lib/logrotate/status /etc/logrotate.conf
EXITVALUE=$?
if [ $EXITVALUE != 0 ]; then
        /usr/bin/logger -t logrotate "ALERT exited abnormally with [$EXITVALUE]"
fi
exit 0
I modified the permissions for the file to executable:
$ sudo chmod +x /etc/cron.daily/logrotate
The first time logfiles should be manually rotated with the following command:
$ /usr/sbin/logrotate -s /var/lib/logrotate/status /etc/logrotate.conf
The result after a few days is:
Code:
$ ls -lrth /var/log/3cxsbc/
total 34M
-rw-r--r-- 1 tcxsbc tcxsbc 7.3M Sep 26 01:27 3cxsbc.log-20190926.gz
-rw-r--r-- 1 tcxsbc tcxsbc 5.4K Sep 26 06:24 3cxsbc.log.mon
-rw-r--r-- 1 tcxsbc tcxsbc 8.8M Sep 27 13:18 3cxsbc.log-20190927.gz
-rw-r--r-- 1 tcxsbc tcxsbc 4.2M Sep 28 06:25 3cxsbc.log-20190928.gz
-rw-r--r-- 1 tcxsbc tcxsbc 6.0M Sep 29 06:25 3cxsbc.log-20190929.gz
-rw-r--r-- 1 tcxsbc tcxsbc 5.9M Sep 30 06:25 3cxsbc.log-20190930.gz
-rw-r--r-- 1 tcxsbc tcxsbc 1.3M Sep 30 06:42 3cxsbc.log
Note: in order to use vim you need to install it first, otherwise use nano
This thread can be closed as resolved.
bosdorf
