SBC on FriendlyELEC NanoPi Duo
ChrisSky
SOHO User
do you get the SBC running on a NanoPi?
Find it better / faster than the Raspery, and it also has a higher data rate on the network card.
Thank you for Feeback
if you have one , try it and give us a REX
I tried it about 10 months ago (with the old SBC version) and failed.
That's why the Question, if it runs at someone?
Hi Chris,
The device is untested and not officially supported, so I would not recommend it for a production environment even if you managed to install it.
The SBC might not be able to install and run on it without the correct dependencies that are Raspberry specific. I think the model you mention also has much less memory at 512mb
bosdorf
