SBC (RASPBERRY) - HOW TO UPDATE TO DEBIAN 12
Arthur.b
Platinum Partner
In the following article: https://www.3cx.com/blog/news/sbc-eol-upgrade/, it is mentioned that SBCs need to be updated to Debian 12. However, for Raspberry Pi devices, it is specified that a Debian 12 image must be reinstalled.
Has anyone found a way to perform this operation remotely via commands without reinstalling?
Have you tried uninstalling the 3CX SBC, updating the Raspi to Debian v12 and then reinstalling the 3CX SBC? The 3CX SBC configuration file can be kept / reinstalled later, but you should back it up first.
Hi fxbastler,
No, i didn't try this method.
Do you know how to remove 3CX SBC paquet without removing the configuration ?
In principle, the entire configuration of the 3CX SBC is in the /etc/3cxsbc.conf file. Back this up beforehand. Unless you are running an apt purge, the file should be retained.
/dev/simon
