Solved SBC Setup for Granstream HT818
sonnyh1
SOHO User
My system was running on a Pi4, but now that is is not supported any more, I moved the system to AWS Cloud.
All the IP phones are setup, but there are 3 POTS and one FAX that was running on the HT818.
I see now that the HT818 needs SBC to connect to my current cloud setup.
I am confused as to where the SBC should be located, cloud, or local.
Any suggestions?
SBC will be local to the ATA.
Reactions: JohnS_3CX
The 3CX Session Border Controller (SBC) is a software service that installs in your local network to allow easy connection of IP Phones to a 3CX instance in the cloud, hosted either in your private cloud or by 3CX.
Thank you,
I have setup the SBC and the HT818 is now registered and working properly
grahamaskew
