search on Forum doesn't work
ronenba
searching on the forum for example BLF or V20 gets error
Yes there’s a minimum of 4 letters per word I think.
Correct, use at least 4 letters for a valid search in the forum.
so i just did a search V20 BLF getting the same error
still this is a search 3 on 3 and will not give results.
For short stuff use google. On the forum you need at least 4 letters.
So if you want to search post regarding BLF features from the PBX, you can”t?
I would like to see all posts for blf v20, but I can't because the search is 4 characters? Don’t you think it is an issue ?
i know this option, thank you
only saying the search on this forum isn't working properly, so they may address it
I am finding many "solutions" for issue in V20 hopping they may address it also in the next update
I expect it's an intentional setting. But yes it does affect searches, for example, "SBC" or "SIP." Also it doesn't allow quoting a phrase.
I too found this infuriating as a lot of searches need the 3 letters SIP, SBC, PBX, BLF, 3CX, etc. until I found a workaround that really does the job very well.
All you need to do is go to the 3CX homepage and use the search function there (magnifiying glass in the top right hand corner of the page). It DOES accept 3 letters and you can refine the results to Forum, Blog, Docs or all of them.
Alternatively use the following url:
https://www.3cx.com/?s=XXX
(replace XXX with your search text).
Problem solved ;)
ARKC
