Send Fax via E-Mail
ZeBuS
SOHO User
Hi everyone,
I’m having an issue with the "Send Fax via E-Mail" option — it doesn’t appear in the dropdown menu in my 3CX v.20 onpremise.
The Fax server is properly configured and everything should be working, but I still can’t receive faxes.
My provider is Telekom, which supports T.38, and with version v18 the fax worked without any problems. Since the update, this option is no longer available and I can’t figure out why.
Does anyone know why the “Send Fax via E-Mail” option might be missing and how to enable it?
Any hints or similar experiences would be greatly appreciated.
Hi go to the pbx admin console ----- advanced ----- fax ---- add ---- add fax forward
There you can forward faxes to a specific user, or just use the global fax server.
Also, validate that the SMTP is working in the system to receive these emails.
Have a good day!
Have a good day!
Hi Alejandro,
I tried what you suggested, but it didn’t work, because it forces me to set a default route on the trunk and doesn’t let me select it without the fax server’s extension or “send via fax.”
Only by setting it to call an external number and making that number the fax server’s extension does it work. In the end, I managed to get it working by selecting “external call” as the default route in the trunk and then manually entering the fax server’s extension there.
If it's a single number Trunk, you can also cut off the last digit from the main trunk number then add a DID with the full number. This way the default route gets skipped because trunk number lacks the last digit. The call then gets relayed to the (full-length)-DID which can be assigned to the fax.
Hi Alejandro,
Yes, if you only have one DID then the workaround is put any number as the main trunk number that does not match the DID, then you can add the DID in the fax server.
Reactions: KyriacosS_3CX
Graham Robertson
