Sending fax using extensions g.711
Andriy
Forum User
Hi everyone,
Does anyone know if i can send FAXes using normal extension (not Fax extension or Fax server)? I am trying VentaFax and it connects to the extension without problem, but can not send fax with this error:
"Modem detected BUSY signals while playing sound"
The reason why I am asking is
1) I am using PBX express and I want to connect fax soft-phone remotely. I can connect to normal extension by allowing connections outside local LAN in options, but when trying to connect to 88 FAX extension - I am getting this error:
"Block WAN requests is ON. "
2) I have 3 locations, and I would like to use different extensions and DIDs for each of them if possible.
3) My voip provider does not support t38 yet
Thank you.
Hi Andriy,
Be aware inbound FAX works fine with 3CX out of the box but if you want outbound you will need a VoIP gateway (FXS to be precise of).
Also be aware that the FAX server with 3CX only works locally or via a locally routed subnet (like a VPN).
T.38 is the preferred method over G.711 as G.711 is bandwidth intensive but your provider must support T.38 FAX for it to work.
Well,
1) I would prefer to use softphone (like Ventafax) instead of connecting a real Fax machine via FXS - is it possible? I was able to connect to to normal extension from VentaFax and to 88 Fax extension but I still get this error: "Modem detected BUSY signals while playing sound"
2) I know t38 is better, but My voip provider does not support t38 so i have to stick to g711 for now. I have one more provider, that seems to support t38 but it has same problem as described above.
Well this string does suggest that this will work locally: https://www.3cx.com/community/threads/fax-client-out-the-office.48796/
You said in your first post "I am using PBX express and I want to connect fax soft-phone remotely."
If you are remote to the system (and not running across a VPN) it won't work. This is why you are getting "Block WAN requests is ON. " as the FAX server will only serve local, or locally routed clients.
Thank you for reply...
I was getting Block WAN requests is ON but then i tried to connect via SBC - and it worked - at least i was able to register,
But now when I am trying to send a fax - i can hear FAX sounds, but later VentaFax gives this error:
Thank you
gmacinit
