"server error" unable to login
Alina Torn
Hey. I can not log in my free pbx account, I enter the username/password and see only the "server error". How can I restart or fix this?
is it running in a pbxexpress vm or on a computer?
in a pbxexpress
if its google, cloud.google.com > console "upper right" > 3 bars on left top dropdown menu to > compute engine > top menu to vm instances > you should see a list of your vm's if you do not, drop down menu at top and select a project. on the right of your vm witch will let you stop and restart your vm.9601
it's installed using 3CX pbxexpress so I only have access to the management interface and 3CX user account
Reactions: Alina Torn
Thanks, good advice. Sorry, that I did not know this before. But the question remains, how do I login or reboot management interface
Hi Alina,
Since this is a free instance you will not be able to reboot it directly. Can you please try to log in again now?
Thank you very much, John! We do not use all the declared all of the free version functions, but sometimes the CPU load reaches 100%. Could you tell me what the problem was?
I will get back to you in a private message
GothamUser
