Solved "Server error" when login in
thierrylaurent
All worked fine for more than 1 year, now I get the message "Server error" when I login through the web interface of the console management xxxx.my3cx.fr
I found other with the same issue, but I cannot apply any solution since I cannot login through a ssh connexion to the 3cx pbx express server (none of my login works, and I'm not sure which one should)
  • 3CX Version :Standard Annual v16.0 Update 5 (Build 611)
  • Server OS / Host : PBX Express Google
  • Trunk Provider : OVH
Can you check that your services are running?
You can log into your Google Cloud Platform panel, go to VM instances and find your vm.
It should have a SSH button on the side
Try to reboot the machine or do sudo 3CXStopServices && 3CXStartServices
Hi John,
Thanks for your reply.
I forgot to mention that I do not find my VM instance... it is empty
Oops, it was not a google PBX Express, but an OVH one.
Rebooted it, and it's ok!
Thanks for your help, very sorry for the disturbance! :rolleyes:
No worries, glad everything is ok!
EMMEPICASA
