"Server Error" when trying to login
sbowers
Gold Partner
Greetings,
I know this isn't a technical support forum. I am hoping that there might be some people who have experience with Linux that can give me some insight.
I have done some digging on this problem. First, here is the system design
On prem Debian 10 server running 16.0.0.1581.
I pulled up the logs and found that networking.service is in a failed state.
I tried to disabled the NetworkManager but it says that itn't not present. Since I am not an expert with Linux I am not sure if this is pertinent. I ran the following commands and they all passed:
ip address
ip route
cat /etc/network/interfaces
cat /etc/resolv.conf
cat /etc/nsswitch.conf
nslookup ubuntu.com
dig ubuntuforums.org
ping 192.168.161.254
Here is the configuration of my NICs:
The system has worked great for the past two years and now this problem came up where I can't log into the GUI of 3CX. I have restored a backup and restarted the server with no luck. Any ideas?
Sam
Is your 3CX installed on Debian 10 "Buster" ?
This is a not supported configuration (yet).
Please install 3CX on Debian 9 "Stretch" and try again.
Reactions: cobaltit
I am running Domoticz on the same unit where 3CX is installed. The newest version of Domotiz requires Debian 10 (Buster), but this version is not supported by 3CX yet. When will Buster be a supported configuration?
Sorry, Debian 10 is not yet supported.
Do not run Domoticz on the same system as the PBX, your PBX must have its own dedicated installation.
I highly recommend you create separate machines or VMs for what you want to do, and for the 3CX system use our pre-made Debian ISO
https://www.3cx.com/phone-system/download-links/
Reactions: mickeyr61
