Solved Server management console password wrong again
tspjoker
SOHO User
i had a few issue with hosted side of 3cx so i turn it off over night and i just got back in, now my password for management console said incorrect.
i noticed 3cx hosted side have few problem with this so anybody can help me about this?
@tspjoker if you are have multiple wrong attempts to login to your web client and your public ip address has been blacklisted, then if you try to login to the management console, then the same will apply for the management console from this site.
Try from a different public ip address and remove the blacklisted ip from the pbx.
as i said, i havent try to multiple try it out. also my current public IP already allowed list.
how this thing happen when i turn off cloude server over night and then turn on and try to log into and why it said wrong password?
even if i type correct password?
nvm i will reinstalled whole things again faster than waiting for help. thanks
@tspjoker as I mentioned in the ticket based on the video you provided, password from the provisioning tab, is not the password for your web client.
It is for the password for the endpoint in order to register to the pbx.
Password for the web client, is at the welcome email you have.
Also if you install and you restore from backup, passwords might be different.
