Set Status Temporarily Issue
Kwang Mien
Gold Partner
I am using 3cx version 18 Update 7.
I set my status to Away for 15mins in the 3cx Web Client. However, after 15mins, the status did not change back to "Available".
Is there other settings need to configure ?
Regards,
Kwang Mien
Hi Kwang,
I tested this feature just now but in my case it reverted back after 15 mins as you would expect.
Some suggested troubleshooting steps:
- Make sure extension is not already set to Away otherwise you won't notice any changes
- If Auto switching is enabled, disable it and try again
- Ensure your PBX has NTP enabled and is working correctly
- Make sure the status wasn't changed manually while temporary was running, this would cancel the temporary status
Reactions: jed and Kwang Mien
Hi Kwang,
Hi John,
Thanks for the info and test. I tried a few more times, and it seems that the status can return back to "Available" now after 15mins.
I am monitoring it.
Regards,
Kwang Mien
Reactions: jed and JohnS_3CX
AshleyStokes
