Solved Setting up an EOL phone via STUN
Alphabetic
3CX MVP
Hi Guys,
For the hell of it I thought id try set up a Yealink T28P since I had it lying around doing nothing.
Yes, Im aware it's unsupported. However, shouldnt I just be able to provide SIP ID/PW and SIP server and have it register like any other?
I mean the template is still there for it.
I'm getting "Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings "
I'm definately using the right credentials and i've tried turning off the require security certificate on the phone.
Anyone offer some food for though?
John - these two lines needs swapping round in the link above
  • Set the Register Name field to the extension number you want to associate with your Yealink phone
  • Set the User Name field to the extension’s Authentication ID
Thanks for pointing it out, I will report it so we can update it. The guide is from a previous version and this has now indeed changed because we use Auth ID.
GP Concepts
