Sever Error on 3CX App, SSL ERROR, Cisco 7970G and more
Tin_Man
Ok, so I'm brand new to this whole 3CX thing, In fact I'm brand new to the the whole PBX and telephony thing. I'm and IT guy and figured this couldn't be that difficult, boy was I wrong. I started off with incredible pbx, but the whole linux component on top of a complicated phone system was just way over the top so I switch to 3CX, but so far I'm still having a whole host of issues, I'm not even sure where to start. One thing I've learned already is that this whole PBX system, windows or otherwirse, is extremely unforgiving.
Ok, let's start with the my setup. I'm running 3CX as a Virtual machine running Win 10 Pro with the latest uopdates on a dedicated host to which I have full control over. The VM is behind a firewall, however at the moment, to rule out anything more being the issue, I've got a dedicated IP with a 1to1 nat and have windows firewall enabled. This is temporary and since I'm actively working on this server, if by some miracle someone manages to break in, they won't get far. In any case that's my setup. This server is going to be compleatly cloud based. No local provisioning. Ok then, my problems.
1. I've got VOIP.ms as a sip provider and I got it configured in my sip trucks and I have a green light on my registration, as well as Voip.MS website reporting registered, I've got a single outbound rule on my outbound routes that does the clasic 9 prefix and VoiopMS on Route 1. All other routes are blocked. I installed the 3CX app on my phone and registered it, which went smoothly and I attempted to make a call. I get a single simple message stating "server error" and no call. What could be the problem? Where can I see some logs for this?
2. SSL_ERROR_RX_RECORD_TOO_LONG Ok, so I came across this error while attempting to configure this Cisco 7970 ( 7960) phone. Basically, it appears whenever I got to configure this phone on the webpage and re-assign the interface for provisioning from the 10.x.xx.x local ip to the public pbx.mydomain.com address. The web portal has a link to an XML file that I need to download in order to configure this phone and whenever I make that configuration change, I can no longer download the xml and instead get the SSL error.
3. And finally, my last issue, the CISCO 7970G bain of my existance ip phone. I have been trying to get this damn thing to work for weeks now and could really use some help. When I saw that 3CX automatically generaged and XML file when I selected that phone on the list I was so extatic.... but, I guess It's still not going to be that easy after all. I noticed that the 3CX web portal specifically states local registration for this phone, is that the only way this phone will ever work? locally?
If you are going cloud base 3CX, say yourself alot of hassle and use 3CX supported phones that can be configured by sbc server or stun
https://www.3cx.com/sip-phones/
Wow. Thanks for the advice guy, but I'm also kinda surprised. I realize that "get a new phone" would have been suggested, but I don't think a new phone would address problem #1 (the more important issue at the moment) and problem number 2# at least needs a litte explaining, if anyone happens to know why I'm getting that error because I know for sure I'm going to see it again with this system the moment there's anything else I need to download from a provided ink on this web console.
Hi @Tin_Man
Make a call to *777 first and see if you can hear the echo service (to ensure extensions work, before you make other calls). Try to call extension to extension too.
2. Models that are supported can be seen in the link @Saqqara posted. If I remember correctly, this device cannot support the TLS protocol we use for provisioning. Register the extension credentials manually on the phone and it might work, but I would not expect it to perform correctly. Initially, the models we did support were added as legacy models to ease people migrating to 3CX, but they will not receive further support going forward and they were only supported as local LAN phones where SSL was not necessary.
So while you are learning I'd recommend using the soft phone or app so you don't have to deal with any device issues. But yes the 7960 is barely supported and won't work for cloud anyways unless you setup a VPN.
For your outbound calling issues you need to look in the activity log (turn it up to verbose) but first did you follow this guide?
https://www.3cx.com/docs/voip-ms-canadian-sip-trunk/
saranga
