Sever Error
udoka
New User
I can't login to my management console, I'm having server error Please I need urgent help
If your system is installed on a windows machine, you can log in to the windows machine locally and check if all 3CX Services are running. If any service is not running restart it and try to login to the management console again.
If your system is installed on a Linux machine, you need to ssh onto your machine and run the command "systemctl list-units 3CX* postgresql* nginx* " to check what 3CX services are down and run the command "sudo 3CXStartServices" to start any service that is not running.
plese how do i log into the window machine locally?
You can RDP (Remote Desktop Connection) on the windows machine or physically connect to the machine and check the Services MMC in order to check if the 3CX Services are running.
TVV40
