Shared Park BLF
Matt Hood
Gold Partner
Intermediate Cert.
We have a customer using 100% soft phone app 3CX clients on Windows PC's. All 12 extensions are at a single office. 3CX V15.5 is located in their private cloud so all clients are remote connecting to the system.
The issue i'm having is with the 4 Shared Park keys set in each soft phone's BLF side panel. SP1- SP4
They all work as intended but only 3 of the 12 soft phones show the BLF status of the SP keys.The other 9 soft phones just show a grey box as if the key is not configured.
All soft phones are using public IP for registration and provisioning and have 3CX tunnel for remote connections enabled.
any suggestions?
thanks
Reactions: nub
Hi @Matt Hood ,
This is due to the 'Can Park Call' rights.
You can either enable this per extension, or per group.
Per Extension
Extension -> Rights -> Click 'Can Park Calls'
Per Group
Groups -> Group Rights -> Click 'Can Park Calls'
The 3CX Softphones should then have all SP's as Green and will function normally from there.
Reactions: YiannisH_3CX
Texas Clay -
