Shaw SIP trunking
SEGuy
Hi all,
I understand it is officially unsupported but I was curious if anyone had gotten Shaw SIP trunking working reliably with 3CX?
I have the opportunity to get the lines pulled right off my fiber optic line on a self-hosted instance and was curious if anyone had success.
Thanks!
Hi @SEGuy
3CX is compatible with most SIP providers and you could probably make it work with Shaw SIP trunks but that would mean putting in the hours and doing your own testing to make sure everything works correctly. And of course if anything goes wrong you need to know how to fix it.
We explain how everything works here and you can even run through our custom test plan
For supported SIP Trunks we do this for you and we provide a template with the settings ready to go. And we can assist you if anything goes wrong so i would definitely suggest going down that route. https://www.3cx.com/partners/sip-trunks/
tohoken1
