Shortcut to switch to a hidden number
Michael37
I wanted to know if there was a way to program a shortcut key to switch the number display to an unknown number at will before making an external call.
I know that by adding * 4 in front of the number to be dialed it will call an unknown number, but this solution does not suit my client because it is necessary to add * 4 each time in front of the number to dial.
Do you have a solution please?
Hi @Michael37
To confirm, you're wanting to press a button / click a shortcut and all outgoing calls from then on will display your outgoing number as unknown?
Yes that's exactly it
Hi @Michael37,
I'm afraid unfortunately this is not possible at present. This would be best posted in the Ideas section. However only Gold partners and above are able to post in Ideas.
Tech_Support
