Should a DNS lookup of a 3cx stun server return one or two IP's
pecc
Hi Leejor,
Thank you for the feedback (the RFC's make for hardreading:)) but me question is; should one or both IP's associated with a FQDN be returned when querying DNS?
If it do a Tracert on stun-eu.3cx.com , I get one IP, which is to be expected (151.80125.107), but the STUN server is associated with two IPs. as per the 3CX article. I'm not aware of a DNS query returning more than one IP.
Leejor, cheers for the feedback, appreciated.
no, the second one you will not see in DNS lookups, PBX sends a request to know IP, from an unknown IP an answer is sent (this IP sits on the same server). If the PBX gets the Answer from this second IP / Port then the PBX knows it has a working full cone nat.
hughesdouglas
