Significant audio delay identical setup VM vs Raspberry
PaulEmous
Last week I started migrating some (bare-metal) machines to a fresh Windows Server 2019 installation with HyperV. The idea behind it is to clean up the network from loose devices hanging around, gauge performance, and yes, shear entertainment. I found an issue I can't seem to find the answer for.
Anyway this is in my home lab and there is not a lot going on (please read: have 50+ people calling at the same time, being it a QoS thing)
Orignal 3CX install
  • Raspberry Pi 3b+, powered by a PoE hat running v16.05
  • Patton FXO 4112
  • Snom M25 + M300 handset
  • Few softphones
Other then having a slightly slower (responsive) admin console, it is absolutely rock solid. Internal and external calling (including 3CX Bridges) are super smooth. I am aware that this is not advised for a production environment, but me and my partner are the only people using it. It's been running since v16 was in beta and I've had zero issues.
Migration
  • I made a backup of the config (incl. license key)
  • Deployed a fresh install op 3CX (debian) on HyperV, (Gen1).
  • Imported the backup file in the setup
  • I swapped the IP leases so once I rebooted the instance, everything would work as the original setup.
Once I completed the restore, everything came online, and worked as advertised. Everything looked nice and snappy. Nice!
Below de server specs:
  • Xeon 2620v4 @ 2.1Ghz with 32GB running on SSD with 10GBe NIC
  • Windows 2019 Standard with HyperV
  • 3CX on Hyper-V 2 Cores 4GB ram, 10GB
  • Hyper V Client sits at 1% CPU and 40% Memory usage
  • No other VMs active.
  • Server completely idle
  • No copying or data transfer active.
I tried to make a few calls and notice "issues" I couldn't explain.
Problem(s)
  • Calls from handset and softphone have significant delays. Both internal and external.
  • Calls from my Snom M25 M300 have significant degraded sound quality. Almost like an analog phone (The irony)
Troubleshooting
  • I tried to reboot the server
  • Reboot the VM
  • Restart services
  • Reboot M300
  • Reboot Patton 4112
The actions had no impact on the quality or performance
I saved the state of the VM, shut it down, swapped the original IP lease to the Raspberry Pi, plugged in to PoE (powered it on), waited for 3 minutes for the system to boot, 3CX to load and the phone to (re)-provision. Guess what; System works flawlessly. No poor quality on phone and no delays?!
What I know:
  • Network is identical
  • Settings are idential
  • Raspberry Pi is offline when I test it with the HyperV instance (so no IP or license conflict)
  • HyperV is offline when I start the Pi
  • Devices are on the same switch with minimal / no load
  • Everything is hardwired
Any ideas?
Hi, 1 quick check to make is VMQ, if its a broadcom network adapter this needs to be off
Set-NetAdapterVmq -Name "NIC 1" -Enabled $False
Set-NetAdapterVmq -Name "NIC 2" -Enabled $False
You can confirm that VMQ is disabled on the correct network adapters by using the Get-NetAdapterVmq Windows PowerShell command.
Mellanox 10Gbe Connect2 X via DAC onto a Brocade ICX 7450
Mmm. It seems to work! Can't believe this was the problem.
Thank you for pointing that out!
Regards,
Paul
Perfect, glad i could help
Reactions: PaulEmous
Yeah I read that but since I am using a Mellanox 10G NIC one could argue that's it not the same as a Broadcom NetXtreme 1Gb NIC
Ahh I only read the first post of your setup. Maybe 3CX can update to include that card. @JohnS_3CX can you ask your team to update that document?
saranga
