Since update to v18 -> delay picking queue calls
svenv
Since we updated to v18 (build 1880), there is a 2-3 second delay before the callee in the queue can hear me / I can hear the callee.
Regards,
Sven
Hi @svenv,
Can you provide more information?
What devices are you using? Does this happen on the Desktop App / Web Client as well?
  • 3CX Version, 18.0 (Build 1880) - 8 sim calls license
  • Server OS, Debian 10
  • Is the 3CX Server Hosted and where? Hosted with AWS (EC2 - t3.micro)
  • IP Phone Make/Model/Firmware No phones, only web apps
  • Trunk Provider Local trunk provider
Wireshark dump attached.
It happens both on the 3CX mobile app, as well as calling our number from a regular line. The sales team is connected using the web app / plugin in the Edge browser. Desktop app for Windows 10 is not yet ready I was told.
Regards,
Sven
Hi @svenv,
Just checked your capture, it does show a 2-3 second delay, but it is between the Ringing and the Okay, so that's means the delay is happening pre-audio.
Can you try the following:
  1. If you have recordings enabled, disable them.
  2. Dial *888 (which will request a callback), answer it, does the delay exist?
1. Disabling recording doesn't help
2. Dial *888 gives me the echo call service. No delay exists when I pick.
Hi @svenv,
Do you have music on hold in the queue?
If you install the mobile client and call from there, is there a delay?
Can you create another capture using the mobile client?
We do have music on hold in the queue. But even when calling another person directly without a queue there is still a delay.
I tried to reproduce is but somehow now there is no delay. I'll try again in the evening or when it's busy.
Regards,
Sven
Hi @svenv,
Can you clarify: "I tried to reproduce is but somehow now there is no delay."
How did you try to reproduce this?
Sure thing!
WagnerFT
