SIP ALG detection problem
Carsten Reckord
I am struggling with the SIP ALG detection of the firewall checker, and I think there is a part missing from its documentation explaining this bit...
My setup is:
- 3CX 16.0.1078 on a Raspberry Pi 4 with Raspbian Buster
- Router: Unifi Dream Machine UDM (FW 1.8.4, Network Controller 6.0.43)
- ONT: Nokia G-010G-Q (provider is Deutsche Glasfaser)
I have disabled SIP ALG in the UDM (H.323: off, SIP: off), however the SIP ALG check keeps failing. For example my latest run yielded this output:
detecting SIP ALG... detected (received 5b06ac3a ≠ e323e5a7)
In order to understand what was going on, I dumped the traffic on both the Pi's LAN interface and the UDM's WAN interface while running this test. Here's what I got:
  • The SIP INVITE and response messages recorded on both devices are identical
  • Using the documented procedure to check the INVITE's CRC-32 gives me a CRC value of 0xAC1971AF
  • The response header returned by the checker service gives a matching value:
X-CSREQ: ac1971af
X-CSRESP: 5b06ac3a
So the checker service saw the same INVITE message with CRC 0xAC1971AF that was sent out by the Pi. Good.
What it seems to have a problem with is the X-CSRESP value, which matches the left value 5b06ac3a of the error message. However, I have no clue how to generate that or the apparently expected value of e323e5a7 from the SIP packets. Throwing the SIP reponse as a whole or parts of it against the CRC-32 service yields completely different values.
Can somebody clarify how I can dig into what exactly is the mismatch here?
You are troubleshooting the wrong part. The most likely scenario is the ONT or something upstream has SIP ALG on. I've never had a problem with Ubiquiti equipment failing SIP ALG check when turned off.
Yes, I'm assuming that. But my experience with their support is that it helps a lot to know exactly what is going on and what I want from them. So I'm trying to understand what exactly it is that is altered in the SIP exchange.
(Also, I'm just naturally curious ;P)
Jordius
