SIP Error
nareach
Forum User
I have 16 sip extensions and 4 trunk
i cannot use context: from-internal in sip extensions.
when i use queue for got incoming call it will not generate to any of my agent but when i use from-internal-additional and i need to change file in extension-additional.conf in part [from-queue]
change from-internal to from-internal-additional to get incoming call in queue.
i notice that it not running well with this temporary method.
i want to use from-internal as default method in sip context.
i want you all help me to solve this issue.
thanks.
Try to call context file with command: include extension-additional.conf in context from-internal. Let me know what happen.
Best regards,
Milan
I am not clear, please explain me clearly
It working now thank so much for your help
in Extensions.conf file under context [from-internal] type include from_internal, exmaple:
[from-internal]
include extensions_additional.conf
OR
to call the context [from-internal-additional] in extensions.conf file, this example:
[from-internal]
include => from-internal-additional
Best regards,
MIlan
It work now thanks for your help.
Welcome any time friend.
Sometime it work and sometime it not work, i do not what is the problem.
HI,
try this command :
Enter in Asterisk console : 1. asterisk -rv => dialplan reload and 2. /etc/init.d/asterisk restart
Best regards,
Milan
What is arterisk console?
please help me to do this?
i cannot type it in asterisk CLI.
it show error.
More information about error
When i type this : asterisk -rv in to command box it show this error:
No such command 'asterisk -rv' (type 'core show help asterisk -rv' for other possible commands)
Try this: asterisk -rvvvv or asterisk -r
Still not working.
i use elastix 2.4
HI
Type on linux console : asterisk "core show help asterisk"
And check whether it was started asterisk service, type
/etc/init.d/asterisk status, if not
/etc/init.d/asterisk start
Best regards,
Milan
I use elastix via web gui now.
Enter in linux console, if elastix pc are in your room or office just enter in him or connect over ssh like this:
ssh root@ip_address -p 22
password:....
Not web gui
Best regards,
Milan
LKU
