- Joined
- Jan 21, 2022
- Messages
- 14
- Reaction score
- 1
Hosted 3CX in Azure for 18+ months.
Was slowly migrating to 3CX from an on-premise PBX that previously forwarded calls over to 3CX.
Calls now come directly from Twilio trunk to 3CX and some failed calls started occurring.
Sporadic 408 errors in the Twilio logs for a few calls directly from Twilio to 3CX.
Azure Network Security Group log show call traffic, but no record of call in activity log.
PCAP log shows 4 INVITE attempts within the call with no responses from 3CX server.
After the failure, Twilio appears to attempt a second call which usually, but not always, connects just fine and appears in the activity log as expected.
The second call is usually from a different Twilio IP, but not always.
Some times a successful call minutes before the issue comes from the exact same Twilio signaling IP as the failed call.
Other times a call a few minutes later from the same signaling IP connects properly.
I have:
1) Run the Firewall Check
2) Reviewed Azure Network Security Group logs
3) Verified that the Twilio IP ranges are in the Azure Network Security Group and 3CX IP Blacklist configurations
4) Replicated with multiple inbound phone numbers (DID)
Other than the Activity log, is there any other network activity log that should be reviewed?
I am using default Anti-Hacking settings. Are there any other settings to check that impact initial SIP connections?
Thank you in advance for your suggestions.
I have:
