Sip Template
GeraldLluca
If i want to change a generic sip template:
Code:
<field name="ParameterOut" custom="" parameter="FromHostPart">$GWHostPort</field>
to show the hosted pbx public ip instead of the gateway/provider ip.
What would be the best way to go for it please, can i use another variable like OutHostPort ? or maybe just set the ip manually?
Thanks for your time.
You will need to use the "ContactUri" variable:
Code:
<field name="ParameterOut" custom="" parameter="FromHostPart">$ContactUri</field>
You can find more details here.
Reactions: GeraldLluca
tohoken1
