Solved SIP Trunk Bridge
meloglaze
Hello All,
I have a SIP trunk setup (w/your preferred supported SIP trunk provider)
To use my Grandstream PBX with the SIP trunk here the instructions say I need to use a Bridge
(https://www.3cx.com/docs/manual/connecting-pbx-bridges/)
-however, when I try to add a Bridge, I’m getting a pop-up ‘Feature is only available in Pro/Enterprise’ (see screenshot)
-under the xxxx.mn.3cx.us I upgraded it to Pro (one year free ver)
-even after upgrade I’m still getting pop-up
From my account login, it shows Pro
Am I correct in order to use my Grandstream UCM6202 PBX I need to add in the Bridge?
-if so, is the above here correct?
-does it look like I have Pro installed? (it shows it...)
-or, am I missing something key here?
Please let me know.
Thanks,
-Ronald
Does dashboard of the PBX show it's pro? Refresh the license
/#/app/settings/license
Went to the Dashboard and it actually did say 'Professional Annual'
-thought to just click on sync license > that did it > and now it's adding it in
-Nice Job!
Cheers,
-Ronald
@meloglaze
I recommend removing that screenshot as it has your license key
Also in your first post the screenshot has your 3CX url.
How do you modify your post?
@meloglaze
Do you know how I modify my original post? Or where I go to delete attachments?
Usually an edit button shows:
I have deleted the screenshots. Hopefully in time. For future reference please try not to post sensitive information on the public forum.
Hello Yiannish, That just never occurred to me, nice that others can help! :)
-once again thanks for your help,
Glad to hear that! :)
Reactions: meloglaze
lastshadow
