SIP Trunk Outbound Parameters
comfident
How can i configure in 3CX, that the SIP Header (Values for INVITE, CONTACT, FROM, TO and P-Preferred-Identity) for outgoing calls is sent in following format:
INVITE sip:[email protected];user=phone SIP/2.0
Allow: PRACK,ACK,CANCEL,BYE,SUBSCRIBE,NOTIFY,INVITE,REFER,OPTIONS,PUBLISH,INFO,UPDATE,REGISTER
Call-ID: ...
Contact: <sip:[email protected]>
Content-Type: application/sdp
CSeq: 615 INVITE
Max-Forwards: 70
P-Preferred-Identity: <sip:[email protected]>
Privacy: none
To: <sip:[email protected];user=phone>
Via: SIP/2.0/UDP 81.189.23.98;branch=...
Content-Length: …
<SDP Info>
Regards
Hi @comfident outbound parameters must be configured based on the voip provider needs, if you are using an unsupported voip provider you will have to contact them. More information about outbound calls please click here.
We always recommend using a supported voip provider where you will be able to use the template designed for the specific voip provider, so outbound and parameters will be configured automatically.
Here you can check the supported voip providers
awan05
