SIP Trunk > PBX Delivers Audio enabled or disabled?
Frank86
Is it recommended to leave PBX Delivers Audio (SIP Trunks > Options > Advanced) enabled or disabled?
In my opinion, you should only enable this if your having Audio issues between endpoint OR if you are using some very old IP phones.
I
Reactions: nub
It is enabled by default when I set up a new SIP trunk (Flowroute, Telnyx), and I think I saw a 3CX page that said that this option should be left enabled under SIP trunks but not under Extensions (but I can't find that page now). So I'm confused.
I stand corrected as I think I misread your initial questions.
Yes, it should be enabled for the SIP Trunk, but not under the individual extension, unless you are having Audio issues with the extension.
Reactions: Frank86
If it's enabled in the template you should leave it as that's how it was tested/certified.
Reactions: Frank86
It is recommended to leave this option enabled.
Texas Clay -
