SIP Trunk Provider in Jamaica
jaume.casanovas
Platinum Partner
We currently have a client in Spain who has a branch in Jamaica. This client wants to contract Jamaican public numbering. Do you recommend any VoIP service provider in Jamaica or another that provides service there? thank you
Hello @jaume.casanovas
If you would like to use a supported SIP trunk provider we would suggest seeing our SIP Trunk Providers - Worldwide, as there are no supported SIP trunk providers in Jamaika at the moment.
Additionally, you could use another supported SIP trunk provider from a different country but also please contact the provider to inform you about their cost rates.
Please see our Supported SIP Trunk Providers
Ok, ningún problema. Espero tus comunicaciones. Gracias
We used Island Tel a few years ago for our Jamaican customer.
thanks @CentrexJ
Do you have a link for contract the service?
thanks @CentrexJ
Unfortunately I don't. It was a while ago and the customer found them and put us in touch. A search of sip provider Jamaica does show a few providers though, but I don't see Island Tel, they may have a new name.
Reactions: NatalyS_3CX
thenks @CentrexJ
Yes, for this reason I have asked you, since I could not find it in the search engine. If you could have the contact provided by your client, I would appreciate it. Thank you
I use a local Jamaican based Voip Telco name WOCOM they specialize in Jamaica based sip trunk, very reliable and costs far less that the other options available locally.
Did you got the chance to check out wocomja.com regarding their Jamaica Based SiP Trunk Servies for 3cx?
tohoken1
