SIP-URI inbound calling on 1 Year Hosted Trial
CosteesP
Is there a way to configure inbound SIP-URI calling on the hosted trial?
I saw that in the downloadable version there is an option in the network settings to enable direct calling,
but this page doesn't exist in the hosted version.
Hello @CosteesP
Please note that you will need to host the PBX your self to have access to that feature as the free 3CX hosted instances do not give you access to the network settings of the PBX.
Actually for anyone trying to implement this on the trial, i found a workaround.
You have to setup a SIP Trunk, with incoming calls only, with your 3CX's public IP (not the IP you are connecting from), and set the main no. to just a number you will be calling to (e.g. 1001).
After setting up inbound routes with DIDs, you can make a call to 1001@<your domain>:5060 and it will be redirected to your system.
