Sipgate - Call forward caller ID settings
Shragi Leitner
Forum User
Has anyone got the right configuration to set up Sipgate UK so forwarded calls will display the originators called ID?
As per Sipgate customer service:
sipgate trunking does support the option clip-no-screening, which means that the initial number/caller id will be forwarded to an external number or device.
I am not sure how to configure this with a 3CX, but usually it should be possible with this PBX.
Any advice would be immensely appreciated.
Many thanks!
Reactions: N_G
Hi. Thanks for your advice. I've just tried them all. I have noticed some slight iterations between them, but none seem to work for Sipgate. :(
What i meant was you could switch to a supported provider, not use their templates for Sipgate. Each provider is different and requires its own template
Reactions: N_G
Kayla Norris
