Skype gateway Set up issues
Jonners59
I have been trying to install the Skype Gateway all day with no joy.
I backed up my system and then downloaded and installed the latest system upgrade, then restored the config.
I setup the Gateway accounts on the 3CX - 3 of them....
I then downloaded the Skype gateway SW, deactivated the UAC and then installed the SW... It then stops at setting up the User Account. It just hangs. I have left it for a couple of hours, no movement. To stop it I have toi use the ctrl + Alt + Del, which can't be healthy.
I have tried several times and I have also tried on two another machines. Any ideas...?
As far as the large number of sessions issue..did you make sure your GW machine was not acting as a supernode?
http://www.3cx.com/forums/excessive-sessions-by-skype-causing-network-failure-11308.html#p57863
Danny
In answer to your question... Probably. I started down that road early last year, but got stuck in complex changes to my server to block and in so doing I got stuck.. I asked questions but got no further replies.
Comresource
When I raised the various topics - yes, there were more than 1, it was relevant at the time and all info was given. I even had audio calls and Telnets with the helpdesk. As stated I have given up on it. It would have been nice, but not essential. Besides there are too many limitations on the functionality and the issue is probably as Danny has stated rather than as simple as the latest install exe
I am now considering Unison which is a full UC solution.
Jake_Southern
