Slow migration from Samsung Officeserv PBX to 3CX by linking them together
jellibelli
Forum User
Given that PBXen probably don't like talking together much, this may well be impractical. Please let me know.
I currently have a hotel running on a fairly new Samsung Officeserv 7200 PBX. It has about 55 analog extensions and 3 digital, connecting to a SIP trunk for inbound/outbound calls. I don't have the cash to replace this all at once, but want to set up a migration pathway.
I will keep the Samsung PBX as the main gateway as it is set up like that already. I want to somehow slave a new 3CX PBX to the Samsung and have it handle just the extensions that we have migrated from analog to a new SIP handset. Obviously some config is needed so that each PBX knows where to find the extensions.
I will then slowly migrate the old analog handsets that fail or need replacing (or as I have cash) across to the SIP handsets and add them to the 3CX PBX. At some stage a number of years in the future we will finish it off by migrating everything else and getting rid of the Samsung. The cost of programming for changing each extension I expect to be NIL after the first one, as it should be something that I can handle myself once I'm shown what to do.
If already answered, or there is already information about this online, please point me in that direction. I haven't found it in my searches.
Does this seem possible? practical? reasonable?
If you can register a new trunk, on the old PBX to a SIP provider, then you might be able to do that to a Bridge trunk on 3CX.
https://www.3cx.com/docs/
You would then have to create a routing plan in both the old PBX and 3CX to allow calls to go back and forth. Caller ID may be another issue altogether. Success will probably depend on how flexible the old PBX is at routing numbers, to a trunk, that are not full PSTN numbers.
Wecare_ITA
