SMB Backup Location
zSeriesGuy
I'm new to 3CX.
Running debian 3CX trying to set up backups to SMB share on Windows Server 2016.
I'm getting "cannot connect to SMB".
I have tried both hostname and IP address in the Network Path. Using /, not \.
I have my domain/username/password defined correctly. At least I think I do.
I am attempting the connection using a Windows domain admin-level account as a test. If I get it working, I'll switch to a non-admin account. So permissions should not be an issue.
smb://192.168.1.250/3CXBackups
Is there some apt install that needs to be done on the debian install for smb client support to the Windows Server? SMBV1 and SMBV2 appear to be enabled.
What am I missing? Any suggestions? Anyone have this working?
DC uses LAN Manager Authentication default value is 3 I believe which only responds to NTLMv2 authentication. Im going to change this value to 2 which will accept NTLMv1 and LM authentication but will use NTLMv2 if possible. Will get back to you once the server has rebooted.
https://docs.microsoft.com/en-us/wi...ork-security-lan-manager-authentication-level
HKLM\System\CurrentControlSet\Control\Lsa\LmCompatibilityLevel
After testing, this is not the setting causing the issue.
I've found the cause.
Local security policy of "Microsoft Network Server: Digitally sign communications (Always)" when this is set to ENABLED then you cannot SMB from 3CX.
This is enforced in the default domain controller GPO.
Without reducing security on the DC I think the Linux side needs to be reconfigured somewhere.
We did some preliminary checks and it looks like the library we are using for SMB does not support SMB signing, so as @kieferschild found, option "Microsoft Network Server: Digitally sign communications (Always)" needs to be disabled.
This apparently is by default enabled on DCs.
We will check though if the library can support this, but for the time being it is best to not have a network share on a DC. The alternative would be to disable this option, but I am not sure if this is a good idea from a security perspective...
Good news guys, we have found a solution to this, so in Update 5 we should be able to deal with SMB with the "Microsoft Network Server: Digitally sign communications (Always)" option enabled.
Excellent news
Reactions: NickD_3CX
Thanks for updating us!
Excellent!!! Thank you so much.
Hassan Murasan
