Solved SMB ISO issue
biggreyphone
I am trying to reinstall the 3CX SBC ISO from scratch from a USB drive onto a different Intel NUC I have. I keep getting the error message "3cx sbc download failed to retrieve the preconfiguration file" during install. Upon searching the forum, I see that this was previously seen to be an issue. I am not using any proxies or limitations on my network and is not being blocked. I am able to download the Debian ISO and install the SBC this way but see there may be future update issues with Debian using this pathway. Does the pathway on the ISO need to be updated or is there something else I am missing?
The 3CX ISO needs to be able to connect to the internet or it will fail with errors like this.
Make sure it has a valid IP (via DHCP or static) and that you aren't blocking outbound connections.
Reactions: biggreyphone
Thanks. Outbound connections aren't blocked. I tried both DHCP and static setting DNS to both 8.8.8.8 and 1.1.1.1 and neither worked. It's weird because I can download and install the Debian updates through an ISO fine.
Hi @biggreyphone In the same network where you are installing the SBC, if you enter the url in the browser https://downloads-global.3cx.com/downloads/debian12iso/preseed_12.5.0_a29bc3d.txt do you see it? check it directly from the machine can you get it using wget ?
Reactions: JohnS_3CX
Have you tried a simple test like pinging google.com?
I have also seen in the past restrictions in the firewall such as content filtering / geo blocking and such. Check firewall logs if you're sure you're good on the client.
Reactions: Alejandro_3CX
Yeah I can ping. It seems to be specifically associated with the 3CX ISO image. It may be secondary to the NIC on the Intel NUC not working with this very basic ISO. I guess I could also try a USB Ethernet interface to see if that makes a difference. If I install a normal Debian ISO image, it works fine. I am still playing around with this.
As 3CX ISO is basically an Debian Netinstall ISO with Preseed File Loaded via URL. If a standard Net Inst Debian ISO works. The 3CX one should also work.
Ensure your Firewall does not make Web or TLS inspection as this would cause the Firewall to do Man in the Middle with a CA Cert the ISO doesn't trust.
And check if the Time / Date of your NUC is current. As Certificates only work if time is correct.
But as said if the Default Debian ISO works so should the 3CX one.
Thanks. Time on the NUC was off.
KylieWilderman
